- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
In Android 6.0, it's not certain that you can turn off the camera shutter sound. It depends on the SIM-card used in the phone and it's according to the Android specification. The menu option to turn off the shutter sound might become available if you remove your SIM card.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
did you update your phone via PCC? or did you flash it?
some regions in the world does not allow sound of camera to be disabled.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I did not flush it, it only shows notification to me for updating OS.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Sanaza Hi
Could you confirm whether the camera sounds or not without the sim card inserted in your phone ?
When you remove the sim card, you should probably get the option under camera settings ( settings under more) to turn off the camera sound.
Also, does taking a screenshot sounds everytime ? even in silent mode ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Nabeel Hello,
I tried your suggestion, and after removing SIM sound toggle appears in the camera app but as I inserted SIM it disappears.
Also I took some screenshots in silent mode and without silent mode and also with SIM and without SIM, every time it sounds while capturing the screenshots.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
For me also, there is no option to disable Shutter Sound in Camara. But after removing the sim, the sound does not occurs. After inserting SIM again it started to sound.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@karthikv@Sanaza It looks like this can be found on other devices with a SIM too:
https://code.google.com/p/android/issues/detail?id=190109
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
U have to put your profile to "Vibrate" !
In Normal I hear "click shutter" but with Vibrate, u have no sound
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Robertods88 That doesn't help, in some countries it cannot be disabled because it will break some regulations.
