Help!! Read Error, Try Again!!
stickypaws
Hi, can someone please help!! I was moving photos and videos from various internal locations onto the SD card (cut and paste) and now my phone keeps bleeping and saying 'read error, try again' I did a shut down and restart but it's still saying it.  Argh what have I done!!!!
I did a back up last night (thankfully) but PC Companion keeps freezing and crashing when I try and do a restore Slightly_frowning_Face
Also, I've just removed my SD card and done a restart and now it's not showing a 'read error' -- all I did was cut and paste from internal to SD card in Windows Explorer, did I do something wrong and how do I fix it?  I'm using a Sandisk Ultra 32gb Micro SD card
Tags (1)
29 REPLIES 29
mahy
Cause your phone is near your credit cards,when nfc is on,your phone thinking found another nfc and this alarm is coming up.
So remove your credit card from your phone case or turn of the nfc.
Katongo
Your the one, that worked for me too. Thanks a million
Benazene
That was perfect advice, man that was driving me craycray! Thanks Slightly_smiling_Face
lettie1
Worked thanks Slightly_smiling_Face
TARAZA
Brilliant thanks for that xxx
Court_80
Thank you so much. I uninstalled nearly every application including my company email after shutting off every app notification manually one by one. I was just about to format my phone. I thought let's see what comes up if I Google the message. I have a flip top cover with a card slot, recently I put my civil id, which has a chip, in the cover, and everytime I folded the cover back the annoying sound would begin. It drove me insane. I really appreciate the fix. Thanks again!
Dunia
I got error when trying to sign in to website and this problem i have it just from my Xperia z 1 and error is "1 error prohibited this record from being saved"
But i can sign it from other cell phones need answers please.
Amber_Miller
I'm having the same problem. I have done a factory reset on my phone and turned it on then off and I've turned it off, taken my sd card out, waited 10 - 15 minutes before putting it back in then turning it on but it still does it. Do I need to call Sony for a replacement or should I just get a new phone?
Amber_Miller
My phone is the Xperia SP
Rachaelv
Thank you you have answered my question also, it has been driving me mad, thought there was a fault with an app or the actual phone, you've saved me from restoring factory settings/resetting/deleting the whole device! A lot of hassle saved thanks again 😄
