Fast Charging Question-Please?
popeye123
I have Z5 Premium and have charging questions:
Is there any way of checking if fast charging rather than regular charging
Is there anything you need to turn on to fast charge
Looks like samsung fast charge plug & wire does not work-what is the fastest charger I can buy in the US? Also does cable make a difference?
Looks like I need a car charger as well-recommendations?
Advice or information would be appreciated, thanks!
profile.country.RO.title
_alexdon_
Z5P supports Qualcomm Quick Charge 2.0, so you need a compatible cable and adapter to have the feature enabled.
However, if I remember correctly, the samsung adapter has an output of 2 A, which brings it close to a Quick charge adapter. Although, we do not recommend other than Sony original chargers and Qualcomm certified chargers.
alexdon
_alexdon_
alexdon
