But that app uses the built in equalizer, and even the clear+ audio setting doesn't change anything at all.
That app it's not a Sony app, hence you have to contact the developers regarding this bug.
I have got some more information about this and it's up to the app if the equalizer is used or not. It's not on by default for all apps, the developer of an app must state that they want to use it in their code.
I've been using Spotify, Tidal and walkman with the Z3, EQ works fine, I hope it still works with Spotify and Tidal, anyone willing to try Tidal for me ? Also in 4.4.4 EQ applies to everything not just certain apps.
In 5.0.2 Lollipop update equalizer & clear audio+ doesn't work anymore (except in walkman). In 4.4.4 equalizer works without problem! Sony please fix, because I can't listen other content without adjusted equalizer.
