Equalizer problem after lollipop update
ville672
Hi. I just noticed that equalizer is only working with walkman app. It worked just fine in kitkat.
Rickard
Master
I'm afraid i don't know for sure if this decision was made within Sony or by Google but as i understand it, the global Equalizer was removed in Nexus as well and i also found this: http://developer.android.com/reference/android/media/audiofx/Equalizer.html
"NOTE: attaching an Equalizer to the global audio output mix by use of session 0 is deprecated."
100 REPLIES 100
Could you elaborate more? what do you mean by "only working with walkman app"? are you saying that other music players equalizers aren't working? if so, contact the app developers as they have to address that bug.
ville672
I mean that the equalizer is not active when using other apps like youtube.
the equalizer its only for the walkman app, other apps have different settings. Google music has its own equalizer.
ville672
In kitkat it worked for every app.
Thommo
I've not seen this, are you sure you aren't just thinking it applied to all
ville672
Im 100% sure. Maybe it was a bug... But it was really useful.
@ville672
got my hands on a Z3 running 4.4.4, I can't hear the equalizer working on youtube but it does on walkman, any suggestions on how to test this further?
ville672
Nothing. 😕
Let me know if you want me to test something else.
