Double tap to wake up screen function for Sony Xperia Z Ultra
Aryo88Reo
Hi all,
i have a question, how to configure "double tap to wake up screen" on sony xperia z ultra..
thank you so much..
Reo
It's not supported
http://talk.sonymobile.com/t5/Xperia-Z-Ultra/Z-Ultra-4-4-2-14-3-A-0-681-firmware-KitKat-Rolling/m-p/...
Xperia Z Ultra KitKat changelog as per users
  • New Homescreen and locksreen wallpapers.
  • Transparent navigation bar and status bar.
  • New Battery icon.
  • No touch to wake up feature.
  • New start up screen.
  • New KitKat Boot animation.
  • Screenshot option in Power menu.
  • Calendar app updated.
  • Answering machine option in call app.
  • Manage notification settings for particular app.
  • Default SMS app settings.
  • Background Defocus app added in camera.
11 REPLIES 11
Which android version do you have?
Settings > display > tap to wake up
Aryo88Reo
Android 4.4.4 KitKat
there is no that option on display setting.
only :
X-Reality...
brightness
White balance
Auto rotate
Sleep
DayDream
Font Size
Notif light
thanks
This feature was introduced on other devices, if you don't see it on that menu then it's not supported.
It's not supported
  • New Battery icon.
Aryo88Reo
hemhh...what if use the application? application recommendation?
Check the XDA forum
profile.country.RO.title
_alexdon_
This is for Xperia Z:
http://www.xda-developers.com/tap2wake-function-available-on-the-sony-xperia-z-zr-and-zl/
Maybe you can ask there about Z ultra.
alexdon
mohsen31
My dear sony! Please give me dab.tab to wake up.
