Hi. I've noticed that there's no possibility to set "do not disturb mode" to end automatically on next alarm. This feature was available in 5.1.1, why did you remove it?
It comes and goes on mine as well. Not a big problem though as you can us the +1 hour feature until it's close to the alarm setting.
Best advice I can give (as no one from Sony ever responds) is to just wait a few weeks. It may suddenly (without any update being installed) just reappear.
It went and came back like that for me a couple times now.
Don't bother a factory reset. Too much trouble.
This has been forwarded internally but I have no information at the moment. Once I do I will let all of you know,
Ok, but priority mode doesn't work at all. Just roght now: I've turned priority mode on but recieve call with ringtone (in setting have just alarm turned on that's all). Would be really nice to fix it FINALLY because this is long going issue and u have no results with it so far. Poor, very poor
224 had option to stop automaticly slince mode after the alarm,
after lastupdate its gone (also lolilop had this
it was very helpful in case you want to wakeup and not forgot to stop slince mode urself after ur up and dont miss calls afterward
it will back again?
thanks for answers
Same here, on 32.2.A.0.256 no more option to set DND off after next alarm. Turning calendar back manually gives the option back but thats not the acceptable solution. I throw my Windows phones away just because I wanted to avoid such situations but it seems that is following me to Android world. So after every update some features I loved and using just star dissapearing.... Microsof't soution was always to wait until next release of OS which makes all issues go away but never did. What's the cliche in Android world?
hey, what do you mean turning calendar back manually ?
