Cell standby draining battery
Nikola_p
My battery is draining very fast,in battery options i can see cell standby eat 50% off battery ,i dont know why - mobile signal is max
How to fix this,please help
Thank you
8 REPLIES 8
Zero3hero
Do you have a very poor signal? In power management under battery usage details does your mobile network signal show poor reception?
But even that should not be consuming 50% of battery.
Zero3hero
Try restarting your phone In safe mode and keep an eye on it for a few hours to see if something changes.
Phy
Legend
Legend
You could repair the phone with Sony PC Companion
http://support.sonymobile.com/global-en/contactUs/
@Nikola_p
We'll need more info to better assist you
charge the phone 100% use it as you normally would then once the battery reaches 10%
settings > power management > battery > take screenshots of:
1. the list
2. tap on the graph and take a screenshot
3. back > tap on the top 4 items on the list > take a screenshot of each
post them all here or upload the screenshots to box or dropbox or google drive or etc and post the link
Nikola_p
Signal is not poor,its on max
@Nikola_p
post the screenshots.
Lauda
LaikaAvis
Hi! Did you manage to fix the problem? I have the same one now but have no clue what to due!
My phone doesn't even wanna charge because it says the battery is being drained faster then it can charge.
