I have a problem with answering incoming calls on my xperia z5. When someone calls me and I tap "answer" the call end instantly in 0:00. But when I phone someone everything is OK. Is there some settings to do something with it?
Both are off
In this safe mode it worked well so I think the problem can be in some app? Now I unistalled the AVL antivirus and everything works great. Can it be connected with this problem?
OK I thank you very much for your quick reactions and your help. Have a nice day 🙂
I had exactly the same problem and uninstalling AVL solved it. Thank you for this information.
