Battery problem and z5 gets hot
Masper
I am using xperia z5 for three mounths. Its battery life is not able to use for two days and it gets hot so bad. I calculated the total battery capacity and it was 1500 mah. Please help me. Thanks.
Tags (1)
15 REPLIES 15
Graves
I think I didn't do that. Do ı need a repair?
Masper
After used couple of weeks battery gets stronger really, i see that mathematicly but i have no idea about temperature... The only solution i have ; when the device gets hot wash it with cold water 😁
CameronT
Champion
@Graves,
Please do make sure all your apps are up to date with the latest version as they may not be optimised for Marshmallow.
After doing that, please charge your phone to 100%, then use it normally until it reaches 10%.
Once it's at 10% go to Settings > Battery Usage and take screenshots to post here so we can help identify where the drain might be occurring.
Maor
Ryan111
 I'm facing the battery drain issue after update to 224.
And i following some forum, and clear the data from google service.
Seems the battery and overheat issue have some improvement.
Please try.
Settings > Apps > Google Play services > Storage > Manage Space > Clear all data.
Stenli
hello my new battery z5 compact very quickly heated and normal wear Is this congratulated Stiliyan
