battery is draining fast in my sony xperia z1compact after lollipop 5.1.1 update and sony jive is not available
Charge your phone to 100% and use it as usual until it gets down to around 15%, then go to Settings -> Power Mmanagement -> Battery usage and take a screenshot. Tap on the graph and take another screenshot, then post those here so we can assist you.
Note: Battery consumption in Lollipop is realtively higher than Kitkat.
You also can read the post "Sony Z1 Compact battery drop" view the last pages and if you have the same problem, and your phone is around 18 month older you probably have to replaced your battery.
I have around 1.5-2 days of battery life with lollipop depending on type of usage since I replace the battery.
Regars
I also have a suddon onset of battery drainage. No addisional work load, no new apps, only minimum amount of apps, no games at all. I only recieve and make 2 max calls a day. About 5 whatsapp chats and 2 SMS's per day.
Battery charge over night. When I take it out of charger its says 100% charged. By 1pm its 35%, by 6pm 6%
Please advise
barries999
Hi ..My sony Z1 has your problem too..
Sony company should to lunch android marshmallow for sony z1
I hope not - read the problems Z5 users are having.
