Battery drain on marshmallow
Battert
Battery drain on marshmallow is too high, please help.
9 REPLIES 9
Battert
Since marshmallow the battery life time not exceed 4 hrs from cotinouse use and screen on... But before marshmallow was 6 or 7 hrs!!! Is that normal???
CameronT
Champion
Hi @Battert,
Welcome to the community.
There is no official way to return to a previous version of Android I'm afraid. Are you experiencing issues with the latest update?
Battert
Yes the battery life time is too short.. Iam really annoyed! How long does it survive with you sir?!
CameronT
Champion
@Battert,
I just saw you made 3 posts. I have moved them all here to simplify it a bit.
If you are experiencing battery drain issues after an update it could be due to apps updating to be compatible with the new firmware. Make sure all your apps are up to date then charge your phone to full.
If you are still experiencing the same issue, use your phone until it gets to 10% then go to Settings > Battery > Show Battery Usage.
Make a note of how long it took to get to 10% and please take a screenshot of this page in your phone and post it here.
Battert
OK thanks alot..
But I want to know what is the ideal life time for the battery from 100%to 0% please?
CameronT
Champion
@Battert,
It entirely depends on how you use your phone so I cannot make any accurate assumptions without first knowing this information. With normal usage (some texts, some calls, some browsing etc) you could expect a day or more.
With heavy usage, much less. The longer your screen is turned on, the less time your phone will last before needing to be charged again. I would expect about 4-6 hours of on screen time, depending on the brightness level and the apps that you are using.
Battert
I have done as you said and the battery extended for 4 hrs from calling and 2 hrs screen on
Is sthat good?
I cant put a screen shot here
CameronT
Champion
@Battert,
Yes please, show us the screenshot. It will help identify where the problem might be.
Ekembi
Im not sure how to use this forum, but iv got problem with my Z2 , battery has started draining realy fast. im thinking about buying a new battery.
