Android 7.0 32.3.A.0.372 LED Notification Bug
Cioce
There is bug in nougat, Under settings -> notifications, if turning off "sound and vibrations" for an app, the notification LED light does not report notifications.
Currently there is no way to have sound and vibrate turned off and use LED as notification. To use the LED notification, sound+vibrate+peek must be turned on. This was not an issue in 6.0.1
Same problem is related also to Whatsapp, I have removed audio and vibration notification for groups chat, and set led to light blue, but light blue led never blink, it blink white for single chat but just because there is the audio and vibration notification activated for single chat
Tags (2)
5 REPLIES 5
MichalH94
Wait, you have Nougat on Z5 Compact? It has not been released yet...
FrknEgeOztrk
half of e5803's takes nougat. you should look dude. @MichalH9
@Cioce did you make clean install (with Xperia Companion) or just take OTA? it could be cache bug too.
MichalH94
Okay, my mistake, still waiting for it, sorry...
xkcd
Same here on Xperia Z5 Dual E6633
Seems to be a bug in Android itself
https://productforums.google.com/forum/#!topic/nexus/1CVY-gxY2-Q
r3z4x
yes, you are right
in android 6 , there was a option named: " allow peeking", and it was very usefull, in some app like Telegram.
and i set "allow peeking" to OFF mode. because i didnt want, new messege appear like,pop uo, while i am in other app.
but in android 7, they merged this option, in to "sound & vibrate", and because of it,simultaneously we missed the led notification and other alert option.
please seperate "allow peeking" like android 6
