XZ proximity sensor always on
ahyik
My phone's proximity sensor is always on(can notice a small red light, especially in dark), when the screen is on. Is this the correct behavior? I thought the proximity sensor should only works when making call.
Thanks!
profile.country.RO.title
_alexdon_
Yeah, the sensor is on to make adaptive brightness work effectively and correctly as far as I know. You can check this: enable adaptive brightness, cover and sensor and see the glider going down.
alexdon
7 REPLIES 7
_alexdon_
alexdon
ahyik
Yeah, you are correct. No more red light after disable the adaptive brightness. Thank you very much!
_alexdon_
Anytime.
alexdon
VLKBR
My Phone proximity or ambient Light sensor always on. I see small Red Light. Adaptive brightness off but sensor always Red Light?
Yasser10
i have this problem on my xz premium
i think this is normal in xperia devices because many have this problem
Yasser10
I disabled adaptive brightness and the red light still on
Tamersalafy
yes that is true the problem is the infra red emitted is hazardous  or not by simple electronic parts we can confirm that ir radiation is always toward eyes
