I have installed this update 6 times and each time the update is complete, my sony experia xz1 tells me to install the same update again and again and again. What do I do?
Hi @Scottaroon;
Are you sure it is always the same update?
It is normal when you buy a new phone that it installs all the updates released.
Check if is always the same build number under settings>system>about phone.
You are right. I have a different build number after each update. All done now. Thanks
If the buildnumber changes everytime the simply do the updates in this order.
If it is everytime the same build number he solution is to wait after reboot. After the restart, the update procedure continues. Just wait until the message disappears.
