I too have battery drain issues since the latest update.
The phone is only a few weeks old and I've been slowly working my way through the 9 updates, ridiculous that that is, but last night I updated the final one.
On a normal day I wont use any more than 50% battery life, today though I've used 80% in 10 hours with no phone calls and good signal all day.
To coincidental to be anything other than the update.
Provide the following screenshots
follow the steps
Charge the phone 100%
use it as you normally would
once the battery has reached 10%
Settings
Battery
take a screenshot of this
Menu
Consuming apps
Show all consuming apps
take screenshots of the list
tap on the top 5 items/apps on the list and take screenshots of each
post them all here
Thanks uliwooly,
I was charged to 100% this morning so here goes.
Sorry there not in order, that uploader is glitchy.
Thanks Mark.
Don't worry about the order, but I don't see the percentages
Settings > battery > Use since last full charge
I'm begining to suspect the comodo mobile
Update
After not having much progress I called Sony support and gave them my imei, and there advice was a major reset which I have not done yet.
After my call I noticed battery usage was back to normal despite the charge level plumeting before the phone call. Coincidence ?
