Hello,
When I try to write some data to my SD Card (with an phone internal app, or with phone connected to my USB port) the data get corrupted. Anyone else has this problem ? This is hardware problem, maybe ?
I'm running android 2.1, the SD card was tested separately on my computer and works fine !
Thanks in advance
Is that the same SD Card that comes with the phone? Why don't you try with another SD Card? (a stupid suggestion)
Just hope that the SD Card is picky :smileymischief:.
Good luck. Merry Christmas.
I will try with another SD card, and I really hope that the problem is in card (just buy a new one will be really more easy than fix the phone).
Thanks for your help, I will post the results of test later.
Merry Christmas gwhispererz !
Hope to hear the good news. Maybe you can just borrow from friends to test (if possible) ???? Test a few SD Cards before 'investing' your money on another one. Enjoy your Christmas day :D.
I buy another card, its a kingston too, but instead of 8gb, this one have only 4gb, and this one WORKS !
I don't know why only this one works, both works perfectly on computer and have the same file system (FAT).
Thanks for the help.
Great, glad that it is sorted out. A picky phone ;).
