Hello I have an Xperia x10 and I wanted to know why don't they make a battery that last longer?
Performance with the battery will be updated with firmware etc..
Mine has got better with use, too. Give it time, and see if the upgrade to Android 2.1 helps...
You might find it helpful to get Advanced task Manager from the Android Market, too, to ensure that you are not running too many applications in the background. Also, try Menu - Settings - About phone - Battery use to see what has been using the battery. You might find it helpful, for example, to adjust the screen brightness, or to keep the wifi off when you're not using it. Both of those can get very hungry.
I believe that is because through several recharges, you have 'seasoned' the chemical reaction within the battery.
