X10 MINI PRO.
X10 MINI PRO.
How can you delete call history and delete messages fast? I have to delete messages one at a time?...
HELP ASAP!!
2 REPLIES 2
suze
Leader
On the messages I'd download the Handcent app cos it gives you the option to batch delete with a tick box next to each thread. But for an individual thread or message within a thread... on the big X10 long press and it gives you a pop up and delete is one of the options.
On the big, for call history, go into dialer and there is a tab at the bottom 'Call Log' then menu key gives you clear call log. Not sure if its the same on the mini.
To delete entire call log; Open the call log from home screen or menu, then press the left HARD button (four sqares above it), then tap delete list on the screen.
To delete all messages/ conversations with 1 or more contacts: Open messaging from home screen or menu, then press the left HARD button,  tap  Delete several on the screen, then select the contact/s.
Individual messages within a conversation can be deleted by tapping the screen on the message to be deleted then tapping delete (beneath  forward message on the screen)
