Sudden battery drop after 50%
anoopr
Have an xperia e4g for around 2 weeks.
Works quite good except for a battery issue after around 50%
I am not a power user, and a drop from 100% full charge to 50% takes 1.5 days. But once it reaches 50%, it drops down very rapidly and shuts down in 4 hrs, even if the usage is very similar or even less.
Battery Usage shows Android system and Screen taking around 30% each - all others appear ok.
Have gone through some of the discussions and tried things like press power+volume until 3 vibrations, and smilar - but no avail.
Is anyone else facing this issue?
Anoop
11 REPLIES 11
mainey25
I use only 2% of my battery. I charge it fully and then take it off. When it reach 98% it just shut down. When i power it on its either flat or on a low percentage even though it shut down on 98%. I Did reset my phone multiple times but it still the same thing. Is his battery or software problem? what do you think?
DcNdrew
It doesn't show the right percent of charge.
I'm facing this problem too. Try to charge it completely, but don't overcharge! Pull it out as soon as it reaches 100%, and let it discharge to 0. Charge it back again and it should work now. Try to avoid letting it up too long on charger, and discharged under 10%.
Well, the screen may down your battery too. Mine using 40-53%... It was about 20% a year ago and I don't know what happened. I never could use my phone over 3-4 hours, but now it's 20 minutes at the top.
