Hi, Im new to this so apologies if I do anything wrong,
I was having problems getting into my messages earlier on my x10. I kept getting an error message on my page saying an unexpected problem occurred, something along them lines anyway, and I was having to force close. Im now not getting the warning message but all my messages seem to have disappeared. I have 2 messages currently waiting to be opened in my notifications but when I click on the message the message will not come up and only a blank message screen appears.
I really appreciate if someone could shed some light on this for me, many thanks in advance.
Ash
Since all your sms are gone, try clearing data and cache from the Messaging app.
Goto Settings>Applications>Manage applications>MENU>Filter>All>Messaging, clear both data and cache.
Good luck.
Thank you for your reply. Tried clearing data and cache, cleared data but was unable to clear cache as it wasn't available to clear, was there just wasn't able to clear it.
After clearing data it didn't make any difference still getting the same error message, The application Messaging(process com.sonyericsson.conversations) has stopped unexpectedly. Please try again
Unsure what to do now, Im totally baffled.
Ash
How about restarting your phone?
I have tried, taken the battery out, tried running a software repair on the pc companion but when it gets to 3/4 progress it tells me it was unable to repair.
Make sure you are using the latest version of PC Companion for software repair. You might want to try SE Update Service, it does the same thing.
http://www.sonyericsson.com/cws/support/phones/topic/updateyourproductsoftware/xperiax10?cc=sg&lc=en
Good luck.
Thanks for all your help. i have managed to do a repair on the phone and its now sorted. Only problem is, I backed up everything but now its not there so I cant restore it. lol
try to repair your phone once more and see if it does it, also turn off your phone and take out the SD card put it back in, turn it on and see if you can find your files
