hi...im not able to send any texts from my vivazpro..it remains in my outbox..i checked with the network people..they said its nothing to do with my sim service...i need help!!!!...please...
Can you still receive texts?
yes...i can receive texts...cant send any....it remains in my outbox...tried resendin...but doesnt work
First, make sure that you have good network coverage and that you have the correct service centre number for your network.Otherwise, run the SE Update service on your phone.
i just updated the software...its still not working..is there any SMS accelerator i can download for sony ericsson?
Have you tried re-sending the texts with a good network signal? Have you checked the service centre number? I've never heard of an sms accelerator..
Also, check that there isn't anything else in your message settings preventing you from sending texts.
i checked all that...been having this problem for past 3 days...
In that case you have two other options: You can try the "phone repair" option via PC suite, or a Master reset which will wipe your phone, reload the same software back to factory settings and hopefully get rid of any glitches that may be preventing you from sending sms.I had to reset my W395 once in order to be able to receive mms, although I could send them.
