Screen problem
ponyboy
Screen problem
The telephone is on, but screen does not work.
Can`t turn of and where is battery.
This is a PM0210-BV
4 REPLIES 4
Remove the SIM card and check again, if the same problem occur you can try
1. reboot on safe mode
or
2. repair your phone with SUS or PCC
if neither of this work then you must stop by your local Sony Xperia Care
http://www.sonymobile.com/global-en/support/contact-us/
ponyboy
Took out the sim card, and it restarted. Everuthing works fine now.
Thank you very much! :smileysmileythumbsup:
Excellent, if it happens again, just get a new SIM card
