problems with facebook
When I go to facebook through my favourites after I have commented on a story then I can't get back without hitting the back button which takes me back through every step, and then I end up at the start without my comment added. Does anyone know why?? Also my facebook widget seams odd, it keeps flicking back to the start randomly which is so annoying I tend not to bother with it, is this normal or am I going wrong with it all somehow? HELP!!
3 REPLIES 3
Aimee
Enthusiast
I'm sorry to hear that. So I can help you a bit further with this, which Greenheart handset do you have?
Hi, sorry I should have said that shouldn't I!
It's a Hazel.
Thanks x
Johan
Master
I suggest that you try to update the software in your Hazel. You can do that via our Update Service program which you can download from the website.
www.sonyericsson.com/updateservice
Please let me know if you still experience problems after update.
