Hi , my mobile requires a pin number and I forgot it . What should I do ?
It tells you on the download page to install and follow the onscreen instructions ie select phone, switch off your phone and how to connect
Ok . What's your opinion to unlock the pin by hacking ?
I'm beginning to think the phone you speak of is either a lost or stolen phone and has been blocked and you are after a pin to unblock it so it will work on networks again - I think this because hacking phones for a pin number is illegal - I have many times for over a week told you the only way to fix said phone is to do a complete phone repair - If you have done this and it is still asking for a pin then it is network blocked
Software is done thanks for your help thanks all
