I have this problem with my phone at the moment it says i have no phone memory left but i have all the space left as i have not downloaded any applications or uploaded any music onto it the only thing i use it for is sending Sms, Because it is sayin that i have no space it is only allowing me to do emergency calls please help
Daimien
OK if you have got the PC Companion connect the phone up and go to the software update. It will tell you that you are up to date but if you are having problems then use the repair button which should be on screen.
If this doesn't work download Sony Ericsson Update Service and follow the onscreen instructions, from memory select your phone and then it tells you to connect the usb to the PC and then whilst holding the back button insert the usb connector into the phone. It should then read the phone and tell you that you can release the back button. You should then be able to select repair from there... but it is a step by step so pretty easy to follow.
okay yea im trying to update it now, im hoping it to work from here now and then i can try to get it to reset if that doesnt work hopefully
Hey there, just wondering if you got your phone sorted after all the posts flying about the other day.
