Mirrorlink problem SMART FORTWO 2016
tcayatte
Hello,
I have just purchased a Sony Z5 Premium Dual (compatible MirrorLink, and compatible for my vehicle).
When I connect it in USB in my vehicle, the system re-knows the Z5 Sony, he asks me if I want to start MirrorLink.
I make OK.
The compatible apps are visible on the screen of the vehicle, to there everything goes well...
But when I was chosen an app on the screen of the vehicle, that opens it on my telephone and not on the screen of the vehicle.
I tried with all the apps, I have exactly the same problem.
I tested the MirrorLink system of my car with Samsung, it works perfectly.
The problem comes from Z5.
An idea to help me to solve this problem?
6 REPLIES 6
Bandolero
Is your samsung phone on android 6.0 already?
Maybe you may also want to check if this phone is compatible with your car kit.
tcayatte
Yes, both telephones are in 6.0.
The Z5 is compatible with MirrorLink Smart ForTwo.
I had looked before buying it...
Bandolero
hmm, thats kindda odd.
Will try to check and see if there is something that can be done.
Shieldi
Same Problem here, Z5 Premium 6.0.1 and "Bosch Infotainment System" (Suzuki Vitara 2016), any solution?
Hal-
Exactly the same problem with my Suzuki Vitara, Sony Z5 running 6.0.1. I have even had the head unit updated at Suzuki with no joy? Tbh it didn't work with my Sony Z1 either :-S
Michabgm
Hello everyone, not sure if that's connected however I have a z5 premium dual and brand new and im using mirrorlink for the firs time.on my Peugeot Partner 2016 both support mirrorlink however v
When I caonnect the head unit (car) shows only the mirrorlink apps (I have sygic) but when I try ro go back for desktop of my mobile or any other apps, nothing shows on the head unit screen and there is a message "display not supported"
If anyone has an idea of how to solve it that would be heat.
As im new here I would appreciate if can indicate if you feel I should open a new thread for this one.
Thanks in advance
