ive have a new phone i can recieve messages but not send them ,were the message centre number is i enter it, and it wont save has anybody any idea why it wont save and what i can do to rectify the problem thankyou any help would be much appreciated.ps i hope someone from sony erricson sees this and can help thanks again
Don't worry, I am here to help you :smileygrin:... I have to say @moelfreligwy that I have never seen this case before. I recommend you to restart your phone by removing the battery and then try to enter the service center number in your Vivaz. If you can't still enter the number, you need to try updating the software of your phone. Here is the link with the instructions on how to update it: http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/vivaz?cc=gb&lc=en
helllo thanks for your help but my phone is the xperia x8 not the vivaz have you any more suggestions thankyou
Sorry for the misunderstanding. Here is the link for your X8: http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax8?cc=gb&lc=e...
thankyou for the reply i have now sorted the issues out regarding the message number and sending texts it wasnt the phone i had to move to a new sim card and the problems were all rectified so thankyou sony erricson for your help
anke io ho lo stesso problema uffa mi aiutate????nn so l'inglese xo:smileyplain:
That sounds great! .. Let me know if you need any help at all...
