Firmware Update for SE x10
Can anybody tell me when I will be able to update my X10 firmware in the UK without debranding my phone ??
I personally think that this is a disgrace that SE have had two firmware updates since I have brought my phone and I have been unable to have either of them. The only option to get such updates are to debrand the phone, which SE does not support, but yet SE take so long to get updates to the branded phones that this leaves their users no choice but to debrand their handsets.
20 REPLIES 20
From what I've heard the firmware update will be sometime this September.  If anyone knows the details, please advise.
Thanks:smileyplain:
KrazyD
The Android 2.1 update will be available from sometime this month.
I got a notification on my phone yesterday saying there was a software update. I thought this might be the upgrade to 2.1 as it required a pc to do the download. After following all the instructions and waiting what seemed like hours, I was told the install was unsuccessful. My phone now does not turn on at all. Has this happened to anyone else? Is it possible to revert back to the previous software version? I have only had the phone 3 months!!
Plug the phone in to USB and use PC companion repair option, following the on screen instructions.
I dont have pc companion installed and now that my phone has no OS it isn't recognised when plugging into the PC via USB. I have no options, no menu, no start screen, nothing Slightly_frowning_Face
It will start its roll out next week.
how do u know about this?
It's on the product blog. And that is if next week is indeed week 38....
Yeah, I did the same update a couple of days ago.  It is not the Android 2.1 update. I have no clue what this update does.  But, I was able to get it done without a problem.  sorry about what happened to your phone.
