Er_Kannan
Bluetooth Problem
Hello all, I have a great problem with my XPERIA X10 Mini Pro. I am not able to receive any files from my PC (Vaio, Widows Vista). When ever I try to send a file using Bluetooth I receive an error message (even if mobile is paired with pc). This is the same case with other mobile phones also (not able to receive files from other mobile phones using Bluetooth), and at times my device is not even discovered (Please note that I have made my device discoverable and know that it will remain discoverable for 120 seconds only)
Somebody please help me to solve this problem. Please...
Another problem I have encountered with Bluetooth is that when paired with my laptop the phone automatically answers to incoming calls.
Please help me out in the above problems.
11 REPLIES 11
suze
Leader
You have to copy the file from the other phone and then paste it to your phone, into whatever file you want it in. To do this tick the box next to the photo and select edit and copy.  The on local files tab select the file you want to use, Pictures for example and then paste it there.
The bluetooth seems to only allow you to view the picture whilst the connection is open between the two phones.  I just got left with a picture icon with a file name that you describe but not actually an image suitable for viewing.
This is a link to a how to that I tried to make to clear up the confusion....
http://talk.sonyericsson.com/thread/4503?tstart=0
http://www.androlib.com/android.application.nextapp-websharing-pznj.aspx
a far better way that bluetooth to copy files from your PC to your phone without wires Slightly_smiling_Face
