Hello,
yes, I have the same!!! It´s eating away battery!!! Approx 50mAh an hour! Thats 10-12 times what WiFi
does!
Must be an software bug, I installed firmware, switched on/off, took out SIM card, restarted...
NOTHING helped. After one week I got another XZ and again...
Thanks for the recommendation. I tried that about a week ago, and unfortunately, it had no effect.
Hi Fred,
I use hands-free phonecalls for my car (from ZENEC) and a pulse-device (sports) from Polar.
Right now I have thr 3rd XZ and (knock on wood) it´s fine but I don´t know why...
I have the feeling that Bluetooth, once activated trough any device, is not returning to some
kind of sleep / energy saving mode.
@FelixSHH Sounds good so far.
If you should happen to experience this again, could you take a bug report and send it to me? I could then forward it internally for investigation.
To do this:
When the report is ready you will receive a notification. Tap the notification to share it. I suggest you upload it to Google Drive and then choose to share a public link to the upload and include the link in the PM.
@FredXZ If you still experience this you're welcome to send me a bug report as well.
Hello Christofer,
ok, I will do so but (please don´t get this wrong :smileysmileywink:)
I hope I won´t have to write you again...
With best regards
Felix
