probably some app misbehaving .... so you should try to keep your phone in Safe mode n sleep today to check if the problem still persist
For me i would've checked the following things first .... Setting > location > scanning > Wifi n bluetooth scanning is off
or I might try a factory Reset
or Find any app which might be misbehaving ... It's not difficult to figure out ... just check the recently installed apps ...and find out when your phone started behaving like this n which apps you installed that day
