banning incoming calls from one particular phone number on w508
Can I block all incoming calls from one particular phone number? (there is a function to block all or allow from table, but i want to block from table something like "blacklist" of unwanted numbers)
2 REPLIES 2
Dr_Chris
Champion
If you select to accept calls from List only, you will have effectively blacklisted calls from any number not on that list.
there is a bit problem - i will have to manually select each number from my contacts book and move to this List (it will be about 3-4 hundreds) what i think will be absolutely silly if i need only to bun one number
