ANOTHER SATIO PROBLEM
Hello,
I wanted larger memory for my messages and for the many mails i get . but ever since i changed the primary memory to memory card , i stopped receiving any alerts , not even an sms. later then , while i have worked through the internet , i have observed this suggestion to change it to the phone memory so as to receive alerts .it worked and  its so frustrating !!! . is there a way through this ??  is there any one who might have faced the same issue ??
and the other thing i wanted to ask is that are there any good applications for this satio ?? really really tired of searching for a good app Crying_Face . i might have been pleased to have a nokia phone with my symbian Crying_Face atleast for the ovi store :smileysad::smileysad:
Johan
Master
I'm sorry to hear. I suggest that you update or reinstall the phone software to see if that might solve the problem you're having. You can update and reinstall the software using the Update Service program. If you have not installed the Update Service program you can download it from here. www.sonyericsson.com/updateservice
I found this site for Symbian S60 applications.
http://www.frees60.net/
