i would like to replace the battery indicator on the status bar with one that at least shows percents, or a circular one, where chrage level is very intuive, not to JUST ADD a new one, like so many third party apps.
anyone has anything on this with an unrooted phone?
Sadly, it's not possible to change this battery indicator. I could only suggest looking through the Android Market. Maybe, if someone else here on the Support Forum uses a similar app, they could let you know in this thread
