Probably the app is still working in the background.
About the scene,you cannot change scene in 20.7 MP mode.
Really don't know,does the same battery problem occur in safe mode?
Only in 8 MP you can change the scene if I remember.
You should wait for Sam to answer,I am sorry.
The big problem here is that we are not seeing anything out of the ordinary in the Battery Usage section other than the application you are using. However given that this is not the only potential software issue you are facing I would advise trying a firmware repair to see if this helps:
1. Download the PC Companion software from http://www.sonymobile.com/gb/tools/pc-companion/
and install it on your PC.
2. Install and open PC Companion then select Support Zone.
3. Phone Software Update.
4. Start.
5. Repair Phone
6. Continue
7. Accept data removal
8. Next
9. Wait for prepare
10. Select Phone
11. Follow the connection steps
"accept data removal" that's not a good deal
Im pretty sure wrong bar concerning gps usage in battery usage is something related to android 4.4.2
1: i can remember such a problem with my xperia Z after 4.4.2 upgrade, before getting my z2
2: i tried logging location with lifelog on my tablet z (4.4.4) no such a bug (no wrong gps bar)
3: Restarting the phone stops the bar and removes the application from battery usage
I prefer waiting for you to give us new firmware update
Btw any news about z2 updates? Why still no 4.4.4?
