2.3 upgrade problem
2.3 upgrade problem
In the middle of upgrade process, as soon as I connect the usb cable to the phone while press-holding back-button, the computer hangs. I tried many times but same problem repeated. Please advise.
7 REPLIES 7
Hey I have the problem in updating to 2.3 update .
-My PC companion is up to date (just updated)
-My x10i is running 2.1 (last update b4 this 1)
and when i update my phone ... it stops in the 2.prepare saying Installation error ". Cannot install or run software update components" .. Help would be appreciated
//Ryan
click on the link above and install Update Service and try again
the same problem occured ...
http://talk.sonyericsson.com/thread/19735
there's always a way around it
Hi, you have been very helpfull I loaded my upgrade and backup file and all after lots on money on bytes spent. I now have a message that pops up everytime I receive and send a sms. The message reads as follows: "SORRY! The application messaging extension ( process com.sonyericsson.eventstream.telephonyplugin) has stopped unexpectedly please try again." everything else seems to be working fine but I am concerned about this message and I cant delete sms's either. Please help me find a solution to ths problem. I have a X10i and ugraded to android 2.3.3 and uploaded backup and restore and works fine I have all back but this is my problem. please help
Please have a look at the following post
http://talk.sonyericsson.com/message/97689.
Check out the last post from Johan-SEAnswers
