Smart connect missing in the applications loaded at first in the phone, or you can not use a headset. The device does detect them.
Headset not supported keeps popping up any time I try on my earpiece device on my xperia xa2. I have used this same earpiece on this phone and it worked before. So how do i fix this problem urgently. Mind you the earpiece still works very well on my 💻. Thank you
