i did all test to see if gyroscope works and it passed, but in game i cant use it.
Gyroscope is not present in XA2, some apps maybe cheated by accelerometer...
Hi @StoryTeller, I'm sorry to hear about that.
Are you sure that the gyroscope is the sensor that PUBG is taking advantage off? Xperia XA2 does not have the gyroscope sensor, so I just want to make sure that I understand your question correctly.
Could you provide a screenshot of the test results that you are getting in the device settings where it says that the gyroscope test passed?
Get back to me and I will do my best to help you!
