Hi Nikk05,
Welcome to the community.
We will check this and update you as soon as we can.
Maybe some of our members will be able to make some suggestions too.
Best wishes,
Ed
Hi Nikk05,
There isn't much that can be done on that front. blocking sound from leaking outwards only relies on passively reducing the escaping noise (i.e using thick ear cups and a good fit over the ears). So apart from lowering the volume, there's nothing you can do.
Win_88
Ok dokey. Cheers anyway. I will just send them back then.
