hi, I am hearing from several sources that the zx100 reaches optimum performance after it has been operational for a set number of hours playback. Can anyone confirm this for me and if it's true, how many hours is recommended. Many thanks.
Yes because ZX100 uses Oscon capaciors at the output stage, it needs some time for burning in. Approx 100h of listenning is required
Thankyou very much for your help
You're welcome 😃
