SRS- X55 speaker wired to PC soundcard. Sound clipping
trankmast
Hi there,
I'm loving the functionality of my new SRS X-55. No problems with NFC or bluetooth pairing.
But I bought it primarily so I can hook it up wired to my PC sound card.
I'm using an ASUS D2X sound card, connected to the SRS X-55 with a 3.5mm to 3.5mm Van Damme silver plated audio lead. The lead is brand new and I'm experiencing some clipping, overloading. The only way I seem to be able to compensate it by reducing the volume being played by the audio player to around 66%. I usually use VLC player but it does it in windows media player also.
Does this sound normal?
Usually by default the player is set to 100% and you just adjust the volume on the Sony speaker to suit.
0 REPLIES 0
