Can anyone tell me if you can adjust the text size on this mp3 player? I have the
NW-E394 and the text size of the track listings is just a bit too small. Can you tell me if the default text size in the NW-A35 is bigger (how much?) and if it can be adjusted? Thanks
Hi there,
I'm looking into this and will update the thread when I have more information for you.
Best wishes,
Sean Mc
Hi sbendixson,
I don't think it's possible to change the font size of the text in this Walkman.
Win_88
Hi sbendixson,
I don't have exact numbers for the size of the font on each but since the NW-A35 has a bigger screen with higher resolution, it's definitely bigger and much clearer than the NW-E394
Win_88
