sony cdx-g3100uv car stereo not working
trelarenz
Before my car stereo use to flicker on and off as in it used to sometimes reset itself. Then 2 weeks ago eventually it just never turned on again when i turned my car on. Some say the fuse has blown others say it might be the wiring . I need help I cant really afford to buy another stereo so what is the cheapest option.. replacing the fuse? What do you think is the problem and how can It be fixed without having to buy a brand new stereo.
0 REPLIES 0
