hi everyone, I've just had to reset my zx100 twice in two days. The first time it was completely dead and the second time it just locked up, a reset was the only solution on both occasions, as my unit is only weeks old I am a little concerned and I am posting this to try and find out if anyone else has experienced this issue and if it was only a temporary blip. Many thanks.
That doesnt sound right, particularly given it is quite new.
Was there any particular file playing or screen showing at the time?
I would definately keep an eye on it, if resetting a second time hasn't fixed it I would return it to where you purchased it from for an exchange or contact Sony Support.
Thankyou for responding, jumpsuit. No link between the two incidents, so I am a little concerned. I will be keeping an eye it and if it happens again I will contact Sony. Many thanks
You're welcome
