DVD audio for MEX-R1
disco_kid
I have a MEX-R1 car radio/dvd player in my caravan.
According to the user guide I should be able to play MP3s on a DVD on it.
So far, no matter how I have tried creating an MP3 DVD, whenever I load it into the MEX it shows "DISC    READ" and after a while "DISC   ERROR"
The book says the DVD can have up to 100 MP3s .. I have nowhere near approached this number.
Also says they must be 44.1 or 44 khz sampling & 64 to 320 kbps bit rate ..
I have used windows media player to rip to mp3 & to burn as data dvd. can't find a way to see/changed sampling or bit rate.
anyone out there succeeded in burning mp3 dvds that the MEX will play?
10 REPLIES 10
Nobody-in-particular
@disco_kid wrote:
Thanks to all who have offered advice .. will have to abandon, at least for the moment.
Merry Christmas to all contributors
Hi Disco_Kid, playing the Video DVD has at least proved that there is not a problem with MEX-R1 reading DVD's so it could be the burning process or software as the Expert has suggested.
This is an odd one though, another option you could try is to burn a playlist but it may be less stressful in the end to just to create MP3 CD's.
Thank for the Christmas wishes and a Merry Christmas to you as well.
