Bought my VGN-FE41S about 2 months ago. Installed a wireless network and things more or less fine. Used Vaio on holiday and connected to a couple of networks OK, but then since last week I just get a message saying "Cannot find any networks". Used to see a number of networks, including my own. Any ideas what may be wrong? Is it likely that the card is faulty? Any pointers gratefully received as am not particularly technical.
Hi shouter and welcome to Club Vaio.
For starters double click the Wireless LAN icon in the System tray (a green square icon at bottom right of screen) and make sure that “Enable 2.4 GHz Wireless LAN is checked”.
Rich
Thanks for your help. Was initially confused by the "green square", as mine was blue having only the bluetooth enabled. Not sure how this happened! Connection is working fine now.
Shouter
