Why won't my vaio play sound?
jesssicalomax
When I first got my vaio the sound didn't play, but I was told to do something pretty simple and it worked, but it's happened again and can't remember what I did. (it isnt muted or turned on low). Please help me!
rich912
Hi jesssicalomax,
First check that Speaker/HP is selected as the default playback device.
Open Control Panel > Sound > Playback tab – Speaker/HP should have a green tick. If not then right click the device and select ‘Set as Default Device’.
If this fails to work then Open Control Panel > Device Manager > expand Sound, video and gaming controllers > right click the audio device and select properties. Make sure that this has not been disabled.
If neither of the above solves the problem then reinstall the audio driver.
Rich
Go n-éirí an bóthar leat
rich912
Hi jesssicalomax,
Rich
