Which bluetooth mouse works with VAIO builtin tranceiver
Niska
Just wasted my money on a Microsoft Wireless laser mouse 80000. My VAIO AR41S didn't see it. Yet it found a cellphone near by.
Shoud I buy only Sony bluetooth mouse? What specs make a bluetooth mouse compatible with the VAIO? Bluetooth version ? channels ?
Thanks in advance
4 REPLIES 4
Thalamus.
Champion
Hi Niska
Have Charge the mouse for at least one hour before trying to connect via bluetooth..?
Have you tired using the included Microsoft Mini Bluetooth Transceiver.. :thinking:
Oh I guess you did switch the mouse on.. :wink:
davemee
I'm running a VGP-BMS33 which I got from Japan via ebay.
Pretty nice bluetooth mouse, run mine on an AR31S, get at least a month's solid life out of some new duracell batteries, which (by all accounts) is pretty good for bluetooth (I remember early bt mice would drain batteries after around a week). No cute USB chargers or toys, just a solid, aggressively-energy-efficient mouse (it will shut down partially on no use, after being left off for a while, it will completely stand by and require a click or move to reactivate).
2 buttons plus clickwheel, with power toggle and bluetooth 'connect' on the bottom. Silver and black finish makes it fit nicely with the AR styling.
I heard that some MS bluetooth devices only like playing with MS bluetooth receiving hardware.
Niska
Yes, I did charge the rodent for more than an hour, turned it on (it glows for a while on the top but I can't see the LED light under ..)
I didn't try the USB tranceiver as I wanted a mouse which would work with the builtin bluetooth. I mat try just to see if it the mouse works. The VAIO did see the Sony cellular so no trouble there....
I too red post about MS bluetooth mouse being ... selective
I guess I lost 80€ ... 😞
stone69
I'm using a Logitech V270 with my AR31S.
Works absolutely fine. Batteries last very long. The mouse is small and handy, although it might have not all the additional functions that a mouse of today "should have"; just two keys and a scrolling wheel.
I like it.
