Hello,
Can anyone help?
no boot,
only 4 green led's light (on, 1 ,A,arrow pointing up & down)
& charge led flashing orange!
Hmmm that does not sound good..:smileysad:
Maybe worth contacting one of Sony's authorised repairers to find contact details for Sony Vaio support..
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Then Click on the Out of Warranty tab to locate the nearest location.
Hi pepasco47,
welcome to Questions & Answers..:smileyhappy:
Can you hear your vaio running.:smileyconfused:
Hi Thalamus
Thanks for your reply,
cannot hear any sounds from hard drive!
Then click Log-In
